Samasung g4 help!
These are not real from samsung. they are just copy...
If you want a budget chinese phone, i would suggest you get something like Hauwei, Lenovo, ZTE.
Will they still operate the same way as the normal samsungs and will they work in nz ?
I order from them, and from a few others. Most (99.99%) are just knock offs of the real ones. Like what daisymtc said, "Hauwei, Lenovo, ZTE" are the only legit ones. Have you seen the HTC One knock off?!? Like twins on the out side, but way off on the specs.
FYI, most of them phones 'Frequency Band' don't work with U.S/Cell Companies, AT&T, Verizon, etc.
Just do some homework before you go buying.
GL!
GL!
I'm from NZ so will they work here ? and are they similar to the normal S4? like do they operate the same etc??
Probably not since it is just a copy. It might look the same but the hardware used in it and the software is most likely completely different simply because the device is not made by samsung. If you want a cheap, and yet powerful phone I would take a closer look at BLU phones. Specifically Blu Qattro 5.7 HD, Blu Life Play, and Blu studio 5.5. They all have qad core processors and big touch screens paired with a fairly new release of android (I think it's 4.2)
will I still be able to download apps and games and stuff , music etc ? with both that Qattro and the G4 1 ??
They may look similar, but the internal components are much cheaper and lower end. Don't expect support, warranty, OS upgrade, or custom ROM's.
They all look like knock offs to me. You get what you pay for basically.
Just go to your local mobile phone shop and see what genuine phones you can get for the money you have.
Don't buy a knock off!
Just get a blu life play on amazon. It's not a copy of anything because it is made and designed by blu (sort of).It's $209 and it has decent specs, and yes you can downloas apps on it just like on any other android phone.
If you really want a samsung stay away from s3 mini it's crap. Get the galaxy s2 skyrocket, it has better specs, a bigger screen, and is way better under many other aspects. On top of that it costs the same if it's not cheaper.
Okay Honestly.. I dont rele care about apps etc cause I can just use my iPod for that... and I dont care about if the phones legit or not I just wanna new phone because my broke and I want it to look cool. Touch scrn etc.
from here:
http://www.aliexpress.com/premium/category/5090301.html?g=y&needQuery=n&SortType=total_tranpro_desc
Maybe like this one's
http://www.aliexpress.com/item/I930...ual-sim-Dual-camera-cell-phone/636343293.html
http://www.aliexpress.com/item/free-shipping-i9300-phone-with-TV-Option/623445230.html
its going to look like crap and you will be wasting your money. save your money and buy a genuine article, not one of these cheap chinese things...or get a older model S3 that can be had for little to no money on contract.
