Laptop Drivers?
Heku
Hello everyone, bought a Packard Bell EasyNote TE69KB laptop bcuz it was cheap (~225€), i rebooted it to Win7 Ultimate 64-bit, but now i'm having problems finding wlan drivers for it on that OS.. i've searched and tried some, but doesn't work on the laptop..
so does anyone know if there are any working win7 64bit drivers for the PB EN TE69KB
Right click on each device needing a driver and click on properties, then click on the details tab and give me the 4 digit vendor and device ID numbers. They look like this.
ven_xxxx and dev_yyyy where x and y are 4 alphanumeric digits.
SM Bus Controller:
VEN_1022
DEV_780B
Universal Serial Bus (USB) Controller:
VEN_1022
DEV_7814
Then under Network adapters i have the normal icon with a little yellow triangle with a "!"..
Qualcomm Atheros AR956x Wireless Network Adapter:
Device Status: Windows cannot verify the digital signature for the drivers required for this device. A recent hardware or software change might have installed a file that is signed incorrectly or damaged, or that it might be malicious software from an unknown source. (Code 52)
VEN_168C
DEV_0036
so i kinda got the wireless driver but it ain't working.. working driver for that would be nice so i could use my laptop properly..
i think i need to update the video card driver bcuz when i try to play some games the OpenGL problem comes up.. is there an other way to fix OpenGL than updating driver?
Video card... VEN_1002 DEV_9838
You are running a laptop with an APU processor meaning the video is on the cpu. You will need to update the video driver. Under display adapters, what does it say?
Edit - go here and choose to automatically detect and install.
http://support.amd.com/en-us/download
click on download now just underneat of that.
it just says: We were unable to find your product or OS , hmm
edit: under Display adapters it says Standard VGA Graphics Adapter
Thanks very much mate, now it works fine, even Windows Aero theme works and no OpenGL problems!
