As long as you are using a dual link DVI cable you will be able to pus that resolution. HDMI probably won't work for anything over 1200 unless you have HDMI 1.3/1.4/2.0. Anything below that will only work for 1920x1200.
I couldn't find what version it is on your card so I would check with the manufacturer if you are thinking about using HDMI.
What monitor are you looking at?
