what do you think of this config...good?
runangun123
BLUETOOTH: None
CARE2: Cooler Master Thermal Fusion 400 Extreme Performance CPU - Thermal Compound Optimized for Thermal Dissipation
CAS: CFI Taiji Full-Tower Gaming Case w/ 1x 140 & 2x 120mm Fans, Front USB 3.0, HDD Easy Swap Bays & Side-Panel Window
CD: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo Drive (BLACK COLOR)
CD2: None
COOLANT: High-Performance Coolant powered by Koolance (Clear Color)
CPU: Intel(R) Core™ i7-4960X Extreme Edition Six-Core 3.60 GHz 15MB Intel Smart Cache LGA2011 (All Venom OC Certified)
CS_FAN: Maximum Enermax 120MM Case Cooling Fans for selected case (Maximum Silent Operation) (1,000 RPM Black Color with No LED Enlobal Magnetic Barometric Bearing 17 dBA)
FA_HDD: Vigor iSURF II Hard Disk Drive Cooling System (1 x System)
FAN: CyberPowerPC Xtreme Hydro II Liquid Cooling Kit 360MM w/ XSPC RayStorm CPU Block,Dual D5 Pump & Reservoir,AX360 Radiator w/ Triple Fan(CPU & GPU Liquid Cooling,Ultimate Overclocking Performance+Extreme Silence at 18dBA)(All Venom OC Certified)
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer (BLACK COLOR)
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: None
IEEE_CARD: None
IUSB: Internal USB 3.0 4-Port Hub
KEYBOARD1: (Keyboard & Mouse Combo) Cooler Master Storm Devastator Gaming Keyboard & Mouse Combo
MEMORY: 16GB (4GBx4) DDR3/2133MHz Quad Channel Memory (G.SKILL Ripjaws X
MONITOR: 24" Widescreen 1920x1080 LG 24EN33VW-B 5ms LED Backlight, DVI, HDMI Input
MOTHERBOARD: (3-Way SLI/CrossFireX Support) ASUS P9X79 LE Intel X79 Chipset Quad Channel DDR3 ATX w/ Remote GO!, 7.1 HD Audio, GbLAN, 3 Gen3 PCIe X16, 2 PCIe X1 & 1 PCI
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows 8.1 (64-bit Edition)
OVERCLOCK: Extreme OC (Extreme Overclock 20% or more) [+49]
POWERSUPPLY: 1,200 Watts - Cooler Master Silent Pro 80 Plus Gold Power Supply
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: Logitech S120 2.0 Stereo Speaker Set [+19] (Black Color)
VIDEO: AMD Radeon HD 7990 6GB GDDR5 16X PCIe 3.0 Dual GPU Video Card
Im guessing that your getting this from CyberpowerPC and you could probably do better for 3200.(I.E the 7990 cost 700-1000 you could get an R9 290x for less than 600.) I also see no SSD whats the point of 2TB when you dont even have a SSD. A 1,200 PSU is completely overkill.
The list goes on and on, i recommend just building your own, but if the situation demands that you need to buy it pre-built than definitely don't get this.
Yea but is the money worth it just to save 35 sec of time it takes compared to the 7200rmp hard drive .... I kno ur probably going to say u already got 3200 wth does it matter
If your going to spend 3200 dollars on a computer and not even have a SSD that's just stupid. What you have now is stupid you can build a much better computer for less than 3200 dollars.
A 1200W PSU isn't overkill for a completely overclocked, watercooled, dual GPU system. No way. Mine with dual 580s pulled nearly 900W from the wall and im not watercooling the HDDs.
Way overpriced for $3,200.
Why go with an SSD? It's not just the OS that loads in seconds instead of a minute, any application you open is almost instantaneous, once you login you can start to launch applications, you don't have that several second delay while you wait for services to start up. When you play games, they launch faster, load faster, etc.
You're only talking a couple hundred bucks for a good SSD.
what would you price this machine if you were to build it yourself and what would you price it if you were to buy it from a retailer
I could build myself for $2700 roughly. But I would also make some adjustments to make it even cheaper. Retail? I think the price is okay for a pre built.
Id make a few changes to the config however, the 2133 ram is worthless, get 1866, its the max supported by the memory controller and anyone that tells you that faster ram helps with games, is full of BS, save the money and buy another 16 gigs if you feel it, and drop the X to the K version of the chip and you could cut another 500 bucks off the price of the build without any serious losses of performance.
Agreed.
However to others if it costs 2700 to build yourself and 3200 to get someone else to do it (especially the WC and OC), id say its worth it. The warranty, professional cable routing and after sales support is something worth it on a machine like this. Plus if it goes wrong, they fix the whole machine.
Agreed.
thanks this helps a lot and furyrosewood thank you I will do that with my memory and my processer.... that was the type of advice I was expecting to get not DONT DO IT... I was looking for a do this istead of that and I applaude you 2 :)
No worries. Enjoy your build. Btw, the biggest bottleneck in your build is the HDD. An SSD significantly improves performance. I would recommend even a 60GB one for the Windows Installation, and use the other driver for applications and storage.
Other than that, enjoy.
Yea a SSD will change the way the machine behaves significantly, and thats really all i can recommend other than keeping an eye on it and keeping it dusted and cleaned....dust with radiators suck. I would recommend a 120 or greater, considering how much you will shave off from the X series chip, should be able to fit it in.
