Hi,
As the title says, I want to build my own computer. I read about it and I ended with this configuration. I calculated it will cost around 900€, this is about the maximum i want to pay for it, maybe a little bit more.
CPU: intel Core i5-4570S 2.90GHz 6M LGA1150 (178€)
MotherBoard: GigaByte Motherboard GA-Z87X-D3H (138€)
GraphicsCard: Gigabyte GTX650 2GB with 1110MhZ (120€)
SoundCard: Creative SB audigy SE (27€)
RAM: Kingston DDR3 1333Mhz 4GB (4 X 38€= 152€)
HDD: WD 2,5" sata2 500GB scorpio black, with 7200 RPM and 16MB cache (70€)
Case: Coolermaster storm with 2 build-in fans and 1 optional(78€)
PSU: PSU/Builder Ser CX 80+ Bronze 430W EU (41€)
OS: MS windows 7 Home Premium OEM ENGELS DVD (99.5€)
I dont know if this configuration is alright, i hope it is pretty good. hut i have some questions:
- I dont know if there is aplace for DVD reader in the case that i chose.
- I dont know if the PSU is powerfull enough
- Is the cooling suficient ? The case i chose has: 1x 200mm, 1x 120mm and a place for 2 fans on the top of the case
- do I need a SSD ?
- And the most important question: will all the parts fit together ?
Thank you very much for your time!
- do I need a SSD ?
