Hi everyone,
I am about to buy all the parts of my first self built computer, so I'm really not all that experienced with building those things. The system will be sitting in a black Lian-Li PC-A79 (It's too expensive, I know that, I simply fell in love with the case).
My Motherboard will be a Gigabyte GA-Z87X-UD3H and my PSU will be a Corsair TX750M.
So my Case comes with 6 pre-installed 120mm fans (3x front, 2x side and 1x rear) and space for two more 120mm fans on the top of the case, which I will be using for a Corsair H100i. I hope those were all the parts relevant to the questions I'm about to ask.
My motherboard only has 5x fan connectors, so it seems to me that there is not even enough connectors for the fans that come pre-installed. How should I go about setting this up? Do I need a spliter? What spliter should I buy? What should I plug in where?
I tried to understand it all myself, but as I started reading about different voltages, 3pin or 5pin connectors and that kind of stuff, it sort of all was too much. I don't get that. Could somebody explain the thought process involved when buying fans and working out the exact way to set them up in the case? What is a fan controller? Do I have one? Do I need one? Can I get one? Heck, I'm not even sure if the fans get connected to the motherboard or the PSU! Or both... or some here and some there... or somewhere entirely different... you get the idea.
I also read that the fans that come pre-installed with the PC-A79 are pretty low quality, especially considering the noise level. I don't care all that much about noise, but I would like to play my games on speakers without having to crank them up until my neighbors are standing on my doorstep, just so I don't hear my case fizzling around like crazy. Also, I thought some red LED fans would look pretty rad shining through the black mesh of the case (don't lough at me please, I am weird like that). Can I just buy any sort of 120mm fan and replace the stock ones? Are they even replaceable? What red LED fans could you recommend (I don't want to spend too much on them)?
Thanks in advance for any help I might get
! I'm really looking forward to building this thing!
