ihoks
Hey guys,
I have a problem and can’t identify its origin, maybe you have an idea?
It started with my monitors turning black for a few second and coming back with the error message:
“Der Anzeigetreiber "NVIDIA Windows Kernel Mode Driver, Version 331.65" reagiert nicht mehr und wurde wiederhergestellt" meaning that the NVIDIA Windows Kernel Mode Driver, Version 331.65 stopped working and has been restored.
This happened occasionally but recently every day. It happens whilst gaming, after the pc is running for some time as well as directly after boot up and system “easy” application such browsing the web.
Reinstalling the driver didn’t solved it so I reinstalled my windows and stuff (this time OS in English so I can deliver them error messages proper..). I flashed my bios and used all the newest drivers. After one day of running the pc the error hasn’t occurred yet, but every time I move a document, program etc. on my desktop it leaves stripes (schlieren) and produces graphic errors.
I did not found a proper solution on the web so I wrote Gigabyte and got the advice to try a bigger PS since mine only provides 46 instead of 60 ampere at +12V.
Since I don’t have a bigger PS and neither a second and bigger system to put in my GPU and test it I’m not sure what to do. Assuming the PS is the problem which one should I go for? How can I figure out if the PS is the problem? I live in Copenhagen so if someone lives close and can help me out for a box of German beer that would be great
Otherwise I really appreciate any suggestions…
My system:
GTX 760 GV-N760OC-2GD
Corsair CX600M 600W
Intel® Core™ i5-4670K, CPU
G.Skill DIMM 16 GB DDR3-2400 Quad-Kit
MAXIMUS VI HERO
SSD Samsung 840 Series 2,5" 120 GB
Seagate ST1000DM003 1 TB
Seagate Barracuda 3TB, SATA 3
LG GH24NS DVD burner
WLAN-Adapter
Fractal Design ARC MIDI R2
Corsair Hydro Series H90
+ the 3 fans of the cas
Monitors: BenQ 24" 3D LED XL2420T and LG W2361V 58,4 cm (23 Zoll) connected via DVI-D (double link) and HDMI
Ps: I did not OC my system yet, would like to do it but yea should fix the problem first. My GPU temps go up to max 70C and CPU max 60C whilst gaming.
Edit1:
First of all thanks for all the help and comments!
So far so good, day 2 without any black screen and error messages.
Solution: new OS (windows 7 pro), newest driver reinstallation in the fresh system and GPU as the PhysX processor as mentioned by NVX 185. If it the issue occurs again I’ll go for older driver versions from the GPU CD, check cable and monitors.
So far it seems indeed like a buggy NVidia driver. Screw Gigabyte, you guys are the real support team!
Cheers!
My system:
Corsair CX600M 600W
MAXIMUS VI HERO
WLAN-Adapter
Edit1:
Cheers!
