Can't see it but I would assume the 10gb is the system recovery partition.
Then you definately have 2 separate hard drives in your system. Either you bought it used with the 2 drives in it already or you added it. How big is C drive? That would be the drive windows is installed on.
Hi John: i opened up the PC and i saw 2 hard drives they are connected with same cable tape to the mother board..
