I am going to customize a pc in the future for both gaming and working, I work in the fields of 3D modeling, Image editing and Video Editing but at the same time I game a lot, I have everything clear on every other part of the PC except for the Graphics Card which I have very little knowledge on.
Which is the right way to customize this, do I have to get two graphics card that are exactly the same like getting two equal Nvidia GTX so that they behave like a single nvidia Quadro or can I get a Nvidia Quadro and a GTX and have them in the same computer, this is what I dont understand, if I choose the second option a Quadro for 3d modeling and work in general and a GTX for gaming how do I manage both under just one monitor, is it possible? or am i forced to buy two monitors one for each graphic card? also how do I know which application is using what, how can I know if my Maya application is not running under the GTX instead of the Quadro and the other way around how do I know if the Quadro is not accidentally running the games instead of the GTX?
Then the connections, if I want to have GTX and Quadro in the same computer and under one monitor how does the connection happen? would I have to make sure that the Monitor I buy has at least 2 HDMI slots or maybe I can buy a 32inch TV and use it as monitor, they usually have multiple HDMI slots.
Well I really appreciate if anyone could help with this since I am not pro at building PCs.
Thanks!!
Thanks!!
