I am in need of an upgrade. I am on a budget, so I am trying to keep things cheap while still offering a good round performance. The only thing I feel I am spending a little more on is the cpu. I do some gaming, but it is not a major hobby. I wish to be able to run GTA 5 when it is released. My current specs are as follows.
Biostar TA790GXE
4 gb DDR2 ram (Don't remember mhz)
AMD Phenom 965
GTX 660
A four year old 1TB (probably 3 gbs/sec) SATA HDD
I cannot afford a new card at the moment, and I feel like I am not getting the most out of it anyway. My heatsink is old, a thermaltake v1 I have had since 2008 or so. It still works, but the fan is making some noise. I will get a new one as soon as I can but I can't at the start.
What I am planning on getting.
ASUS M5A97 970
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231455
AMD FX-8350 Vishera 4.0GHz (4.2GHz Turbo)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
Seagate Barracuda ST1000DM003 1TB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
This all comes to 450 bucks, about as high as I am willing to go.
So the thermaltake v1 and gtx 660 will be transferred to my new system, as well as my tower and 650W power supply. Ram can be upgraded to 16 gb in a year or two if necessary, as well as a different GPU. This is about as good as I can do, but a lot of you are way more computer savvy than me, and I wanted to hear some ideas if anyone had any to offer. The systems I have built so far have been pretty solid.
Biostar TA790GXE
AMD Phenom 965
GTX 660
ASUS M5A97 970
