Looking for advice
Controller
Hey guys i wanted to ask you guys what parts of my pc i should upgrade. I hope you guys can help me out. My PC components:
System type: Windows 7 64bit
Processor: Intel Core i7-2600k CPU @ 3.40 GHz/3.40 GHz
RAM: 8 GB
Graphic Card: AMD Radeon HD 6900 Series
So im using my pc for gaming. I dont know what other components are important for gaming so you can tell me what else i need to add to the list above. Thanks in advance
Definitely the graphics card, but before i can suggest one what is your case, power supply, your budget, and which 6900 is it (6930, 6950, 6970, or the 6990?)
ok im very very sorry but im a complete starter in that kind of things. How do i check my case and power supply and when i go to the hardware manager and go on graph card it just says amd radeon 6900 hd series idk how to check the specific lol.
My budget is about 200-300 euro
Why exactly do you think you need an upgrade? A Radeon 6900 series graphics card is hardly weak and you have a strong CPU there. Do you really need to spend money on new parts?
I dont need to but i want to in the future and just wanted some advice :(
