Memory filling problem
GT5fan123
Hi guys, it's me again!
I've discovered a strange problem with my laptop.
Two days ago, I deleted some programs that I don't need anymore (they've took circa 500MB - 1GB of HDD space) and now when I've got circa 1.7GB available on the HDD, this laptop starts to fill the HDD on its own! I do not have discovered the possible source for this problem but it's annoying me cause my lappy pops a window that says your hard drive is full.
Do you have any suggestions for this problem?
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
Post the following logs in your next reply.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
Junkware Removal Tool comes directly from Windows Update and I've got the latest version.
NO it does not. You are thinking of Windows malicious software removal tool. They are 2 diffferent things. Please run all programs and post the logs.
