power supply
thair
Hi guys,
I want to buy a new power supply, and I want it silent
Because I have a lot of noise come from my current power supply
So I hope you advice me which kind of power supply should I buy it
Thank you.
My vote is for a CoolerMaster SilentPro :good:
Just need to know your system specs so we can suggest a wattage.
my spec
Hi,
This is my spec
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
The 360w should be enough for you, but with little room for expansion in hardware.
Thank you Pane
If you want some overhead for later upgrades.
Yes, actually I want to upgrade. I try to upgrade my CPU
To core i7 because I need faster, is there anything else should to upgrade it
Beside the processor even I get a faster PC
Thank you
That's a good price on the Corsair 430. I've had one in a homebuilt desktop running a Core2Duo and old nVidia Quadro FX for a few years now without a problem. I'd go with that, but knowing it's going to make a little noise.
Good call, StrangleHold
