Msi 970a-g46
emac227
Any used this board? Looking to upgrade my computer and want to do it cheaply. Would like to oc.
Just to make sure, you will also be buying an AMD CPU, right? You currently have an Intel.
I was hoping for under 200 for CPU and MB. I have a nvidia card I was gonna use but I guess I'll need a new one. Want an atx board and if it fits the budget and will work better then AMD then I'll
Go with a Intel
I have it and have put a couple others in builds as well. It's a pretty solid board. If you're doing much overclocking you're not going to get crazy far. On my Phenom II 955 I got to 4.0GHz from a stock of 3.2GHz without much trouble. With my 8320 I couldn't get past about 4.3GHz stable because I ran out of voltage bumps.
Only other problems I've had were that if I had my GSkill RAM in one of my slots it wouldn't boot. No idea why. I have 4 sticks of RAM. 2 GSkill and 2 Kingston. The Kingston worked fine in that slot but the GSkill didn't. It was weird. Was really a small issue though since it was easily fixed.
It's a solid board and I have no problem recommending it. But if you're expecting a lot of overclocking, remember that it's a sub $100 board.
It will be my first over clock so not expecting too much, just want to have a decent gaming machine. What CPU is a good budget processor to do with that board to over lock for gaming?
FX 6300 or FX 8320 would be good. They're essentially the same but the 8320 had 8 cores and the 6300 has 6.
