BrianCharlie
In my current computer at home I am running a Biostar T series motherboard ( I can't remember right now exactly which model). The mother board comes with a dvi-d, vga, and hdmi port. My issue is that it will only allow 2 of the 3 ports to work at one time. My current set up is two monitors + a tv.. Currently my two monitors use the dvi-d and vga and then the tv uses the hdmi slot.. I switch back and forth between the two ports (VGA/HDMI)..
I was wondering if I could have my two monitors plus the tv working at once, if I get a dvi-d splitter and put both monitors on the dvi-d port and then leave the tv on the HDMI port. Would this allow me to have all three activated at once? even though the motherboard Manuel says it allows 2 at once.
Thanks!
Thanks!
