demonikal
I was coming back from overseas and a bottle of Hraki (Greek liquor) broke in my luggage (carry-on) when my backpack fell out of the backseat of the car when I opened the door. My Dell XPS 13 laptop and Google Nexus 7 were in there. I immediately put them in dry rice for about 4 days. Nada. They won't turn on and I've had them plugged in for 2 days since then. My Nexus warranty was only 12 months and I got in the Fall of 2012 and it doesn't cover liquid-damage anyway. My laptop warranty is also over.
The Nexus, I have no idea what I'm go to do with that. Probably try opening it up eventually for the heck of it, if I know what to replace. But it's an 8 gigabyte Nexus 7, so it might not be worth it to mess around with it. Might just be worth it to buy a 16 GB or 32 GB one.
With the laptop, well that I'm more concerned about because it had for just over one year and I got a lot of use out of it. I just ordered a small tool set for less than $4 that had a T-5 torx bit in it, since I didn't have one that small, but I don't know what to look for - and generally, I don't know what liquid damage usually affects first or the most (i.e. battery only, or motherboard, battery, and just about everything). I figured since this was 40% alcohol, it might actually be less damage than if it had been water, since a lot of the alcohol might have evaporated off, but I don't know that for sure.
So,, really I'm just curious what kind of damage I should look for and if anyone thinks it's worth me buying refurbished parts on Ebay for my Dell XPS 13, if it comes to that.
