lostsoul62
Aren't all SSD drive the same speed, so does it matter which one you buy as long as it's the size you want?
Exactly, just like mechanical drives come in different speeds, so do SSD's. More often than not the cheaper SSD's use lower end memory which offers lower read/write speeds than those found in higher end SSD's.SSDs are the same as mechanical drives. Some are faster then others. Different brands, different controllers, different memory chips and so on.
