Chromecast
aznchris
Not sure if this is the right section, but it seems like it could be. Anyways, would Google's Chromecast work if I already run a 3 monitor setup? Would I need an Active DP adapter for chromecast? Or how does it work with an AMD card?Because as you guys may know, after 2 monitors, every monitor after that needs an active DP adapter I believe. Help? :D Thanks
I think you're confusing what a Chromecast is. It doesn't connect to your PC at all, you plug it into your TV and you use your phone/tablet to control it.
Oh right huh! Sorry I was over thinking it. It was actually thinking of plugging it into my PC then it magically appears on my TV.. LOL.
It can also be controlled from your desktop or laptop but that also has no effect on your 3 monitor setup since the Chromecast is plugged into the TV.
