lostsoul62
You spend a thousand dollars to build a computer. All you need is an i5 for an average user. Why not spend another hundred dollars and get an i7? That's just 10% more because you will use the same motherboard. Now would getting the i7 last another year before you upgrade and if so then it would be worth getting an i7 vs. an i5? Also is getting a (K)series going to be worth getting if I don't overclock or should I get a (K) series incase I want to overclock later so it will last for a little while longer? The problem is if I use my (K) series CPU to upgrade or overclock later on then I have to spend a hundred more dollars for RAM? I'm not sure what to do?
