Hi, for the last month my CPU has very often 99% usage BUT only when I'm not looking.
And by that I mean, when I'm doing something for example in Excel, I can hear that my CPU goes to 99% but when I press ctrl+alt+delete, it stops before I could see what it is, so I left task manager running and was just watching the screen without touching anything, after a minute or two I saw it, its caused by process named "windowsM_x64". But when I moved the mouse to click on it, it immediately disappears.
Using a shortcut I managed to get a screenshot which you can see here:
http://postimg.org/image/gsw1ym95j/
Using the ESET(version 6.0.316.0) I scanned the computer, it found few things which were removed, but the problem persisted so I downloaded this:
http://www.microsoft.com/en-gb/security/pc-security/malware-removal.aspx
it took nearly 6 hours but it didn't found any malware. Is there a program which can record the history of that process and find its source? Because it disappears every time when try to click on it.
Thanks for any advise.
