Virssagòn
It seems like Devil's Canyon will be supported by Z87 boards after all. Just by a BIOS update.
Source: http://blackholetec.com/main/article/devils-canyon-z87-compatible
While Intel had initially said that Haswell "Devil's Canyon" would not be compatible with LGA1150 motherboards based on Intel 8 Series chipset and the rumors spoke of a change in terms of CPU power, it would seem this information is ultimately inaccurate. Indeed the lack of formal compatibility from Intel would only related to the slightly higher TDP of 4 watts, a marginal increase that may be collected by any power LGA1150 board floor, even more the Z87 that are tailored for overclocking. A motherboard manufacturer has also told us that the validation tests on Serie 8 were underway for adding support of Devil's Canyon in the next bios. Here So great news! As a reminder, DC are Haswell with some modifications intended to improve overclocking, especially at the contact between die and HIS but also the power to the back of the CPU filter capacitors. Rumors point to two versions: - Core i5-4690K: 3.5 GHz, Turbo 3.9 GHz (100 MHz vs i5-4670K) - Core i7-4790K: 4.0 GHz, Turbo 4.4 GHz (500 i7-4770K vs MHz)
Their announcement is planned for Computex in early June, so we should know more about the price, availability date and perhaps the contribution of changes in practice. motherboards based on chipset Intel Serie 9 thus lose what was thought to be an advantage, they retain against by the exclusive support Broadwell ... until proven otherwise!
