No worries mate. I think it is a good idea to get a new drive and do it that way. Depending on how rich you feel and how much space you need, i would HIGHLY recommend an SSD - say a
500GB Samsung Evo. This difference in performance between that and a standard HDD is night and day. You can also use your old drive for storage/backup via the USB3.0 caddy.
Either way, get the new drive, and also get a
USB 3.0 2.5" HDD caddy. That way you put the old drive in the caddy, and the new drive i the laptop. Use the
Windows Easy Transfer Files and Settings approach and save it to your existing (old drive).
Before you change over, ensure you have your Windows keys (take note of what Version too e.g. professional, home premium etc) and update your bios, and a burnt copy of windows (links above).
Then swap the drives over
using these instructions (Page 53 - 54).
One further recommendations. With your new drive,
create a partition, say 60GB (or larger) for Windows and another for your files etc. (instructions below). That way in future, its very easy to reinstall Windows without affecting your files partition (Windows sees them as two separate HDD) - meaning you will not have to worry about your files etc with a reinstall.
Install Windows (and create partition)
- Put your NEW drive in the laptop using instructions above.
- Ensure any non-essential hardware is not connected and the laptop is connected to mains power. In fact remove all USB, SD cards etc.
- Ensure that you have all the Essential Drivers from the previous post above on a separate USB drive (not connected to laptop at this stage) so that you can access them after install (where you may not have network drivers) - windows 7 is pretty good a having drivers though.
- Insert your Windows 7 64 bit DVD (assuming done the above)
- Restart
- Press any key to boot from DVD (if it doesn't boot from DVD, restart again and press either F10 or F12 and choose the DVD as priority boot - although it should be default)
Select
Install Now
This Screen Will Show
If connected to the internet (many computers always are),
Select to "Go online" for latest updates.
This screen will show:
Then select the Windows Version you want to install. In your case it will be whatever your key is for - (as per Magic Jelly Bean - 1 & 2 of TIME TO BACK UP YOUR SOFTWARE KEYS AND INSTALL WINDOWS from previous post). It may also be written on the bottom of your Laptop on a COA sticker. Select the right one.
Accept the license terms and click next.
Select "Custom (advanced)"
In this screen you see existing partition (in your case there should just be one). Click "Drive options (advanced)".
Click on New
You can choose to use the entire empty space, or just a part of the space. If you choose to partition (60GB for Windows, the rest for files) then enter 60000. If you have a large disk, then you can make the Windows partition even larger - say 100GB (100000). Then press Apply. Don't format anything.
Windows will, by default, create the "System Reserved" partition.
Now click on the "Disk 0, Partition X" - choose the one that is the same size that you created earlier. Select
next.
Windows will begin installing.
Let it install, it will restart several times.
When you finally install and get to the screen below, DONT ENTER serial yet. Just select "Next" without entering anything.
Complete the "TIME TO INSTALL ESSENTIAL CHIPSET AND LAN DRIVERS, WINDOWS UPDATES AND YOUR PERSONAL FILES" section from previous post. Make sure everything works
BEFORE you enter your key (see 14 under that section).
All going well you'll have a new, activated copy of Windows 7 64 bit. If it all goes horribly wrong, you can re-replace your old drive and be back up and running.
All going well, next job is to go to Disk Manager and create your "Files Partition" or whatever you want to call the remaining space on your HDD that you want to put files and your 'stuff' on. (the part of the disk you didn't install Windows on). Do this by:
- Right click on Computer
- Select Manage
- Select Disk Management in the Left Pane
- Right Click on the Unallocated Partition and Select New Volume
- Follow the Wizard allocating a new drive letter and a quick format naming it what you want (e.g. Files and Documents).
- After a short while, you will have a C: and probably a new E: (D: being the DVD ROM).
After this attach and navigate to your 'old' drive via the USB caddy. Run the Windows Easy Files and Settings transfer again, navigate to your old drive and your new machine will look like your old. Then simply manually install new applications and files form your old one.
Then download
Auslogic Disk Defrag and defrag the entire two partitions using the Defrag and Optimise option.
Update Windows.
Once you've done that, and you're confident that you have all your stuff transferred over, use the external caddy and old drive and perform a backup.
