Video Card upgrade and compatibility?
Videodrome
Thinking about getting this http://www.newegg.com/Product/Product.aspx?Item=N82E16814202090 and this http://www.newegg.com/Product/Product.aspx?Item=N82E16817152054&cm_re=600w-_-17-152-054-_-Product
my comp has a 300w power source and of course the video card is really bad.
I just wanted to know if these would be good upgrades that I could replace my old stuff with, not too sure about the compatibility either though. Any input is appreciated.
Going to use the comp mainly to play videogames and want to have a nicer experience with graphics than I have right now which is the minimum.
System Information
Operating System: Windows 8 64-bit (6.2, Build 9200) (9200.win8_gdr.140309-1509)
Language: English (Regional Setting: English)
System Manufacturer: Hewlett-Packard
System Model: p7-1534
BIOS: 8.15
Processor: AMD A8-5500 APU with Radeon(tm) HD Graphics (4 CPUs), ~3.2GHz
Memory: 8192MB RAM
Available OS Memory: 6808MB RAM
Page File: 1871MB used, 5959MB available
Windows Dir: C:\windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.02.9200.16384 64bit Unicode
Display Devices
Card name: AMD Radeon HD 7560D
Manufacturer: Advanced Micro Devices, Inc.
Chip type: AMD Radeon HD 7560D (0x9904)
DAC type: Internal DAC(400MHz)
Device Type: Full Device
Device Key: Enum\PCI\VEN_1002&DEV_9904&SUBSYS_2AE0103C&REV_00
Display Memory: 3646 MB
Dedicated Memory: 498 MB
Shared Memory: 3147 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: AOC 2269WM
Monitor Model: 2269W
Monitor Id: AOC2269
Native Mode: 1920 x 1080(p) (60.000Hz)
Output Type: HD15
