bill of oz
i have a dell E521 with windows vista, trying to install an IDE hard drive as a second (slave) drive,
my motherboard has two ribbon cable connections, one at the top of the board and one at the bottom of the board which are both occupied by the same ribbon cable,
the ribbon cable goes from the top port, then into my 3.5 disk drive, then into the bottom port, beside the bottom port it says "FLOPPY 1"
my question is.....can i connect my IDE hard drive into either of these two ribbon ports?
if i have to remove my 3.5 drive i dont care,
