What type of virus ??
Boby
my all folder look like apps..i concluded this is a virus and when i installed antivirus virus is gone with its folder content which was 10gb,i retrieved it using a recovery tool but this virus still exist showing foldes as apps.
Does any one knows how to delete this without deleting the folder content ??
Please be generous ..
you can do it using kaspersky rescue disk: it boots from a cd/usb stick and you (update b4 scanning) can scan for viruses, and eliminate them without using your infected windows system
Please post a screenshot so we can see whats going on. I would say your file associations are probably screwed up.
Im COOL man , hell if they wanna give there personal shit to you that's fine. they the one sthats getting brain washed lmfao.
John all he wants is people's personal computer shit. info. I cant stand that SHIT. and I just want people to know they gonna get hacked messing around in here.. showing them logs.. yall no what I mean.
All I can say is amazing and clueless. Completely or hopelessly bewildered, unaware.
i just said a real thing happend in my harddisk, when the folder properties are checked it is named as an application..once when i installed avast antivirus , all folders having video content are disappeared showing it as virus..so now i cant able to use that antivirus..
is there any way to remove it ??
Can you run any EXE files?
Download this file and run it
http://www.raktor.net/exeHelper/exeHelper.com
This should fix your file associations for exe files. Then please do the following.
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
So in your original thread asking for help, please give us a short description of what the problem is and then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
