How much power? Please help
mccoyboy22
ok so heres my setup, i would like to know how much power from my psu i need, this is the only thing ive never understood about building a computer, i have tried 2 different calculators but i want to be on the safe side and get a second opinion.
NZXT Phantom PHAN-001RD Red Steel / Plastic ATX Full Tower Computer Case
WD BLACK SERIES WD2003FZEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236624
EVGA G-SYNC Support GeForce GTX 770 DUAL SuperClocked 4GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card 04G-P4-3774-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130945
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C10D-16GTX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589
MSI Z97-Gaming 7 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130768
Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor BX80646I74790K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
DEEPCOOL GAMMAXX 400 CPU Cooler 4 Heatpipes 120mm PWM Fan with Blue LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16835856005
Kingston SSDNow V300 Series SV300S37A/120G 2.5" 120GB SATA III Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820721107
Also if you have any tips or ideas im completely open to them.
It's just wasted power. Power supplies are more efficient near peak load, so the extra power would just be a waste. In any case, a quality 600W PSU is much better than a crappy 600W and will be able to handle upgrades down the road. If you need more power, you can always get another PSU down the road.
What if i got the 750w? where does that extra power go? it would be for future mods.
It doesn't really go anywhere. 750w would be simply the availability of wattage that your unit could provide.
The same components would pull the same wattage whether you were using a 500w or a 1600w PSU of equivalent efficiency.
