X Xanaduu New Member Aug 17, 2014 #1 Can a internal SSD be used externally with the eSATA port on my motherboards I/O? If so how? Thanks
X Xanaduu New Member Aug 17, 2014 #2 It was answered on OCN and USN/Sata should do the trick. http://www.staples.com/StarTechcom-...6-_-10428703&CID=AFF:6146846:6146846:10428703 Thanks
StrangleHold Moderator Staff member Aug 17, 2014 #3 Xanaduu said: Can a internal SSD be used externally with the eSATA port on my motherboards I/O? If so how? Thanks Click to expand... Just get you a SATA to eSATA powered. It has a SATA/Power connector on one end for your drive. The other end had a USB and a eSATA port
