Hi!
I have 2 PCs in different rooms. I was wondering if connecting PC1 to a router then the RJ45 then back to the modem as well as PC 2 directly to the RJ45 would work... or if there is another solution I need. (See image)
Aside from the fact this would make cabling easier, my roommate needs to constantly reset the router (laptop keeps loosing connection for some reason) and I don't need the rest of the net to suddenly go down every time the router is being reset... thus bypassing the router on PC 2.
Try this link for the image if it's not showing:
http://s18.postimg.org/6t71d6mix/RJ45_Question.png
Thanks!
Thanks!
