Usb 3 drive would be faster only if you have a usb 3 port on your computer. Hi res just means the file size will be bigger and take longer to transfer on usb 2.
It doesn't record a temporary file then put it on my HDD. It records the show directly off the air and onto the HDD as it happens, and it closes the file after the show ends/when I program it to stop.
I have USB 3.0 ports, I just need the drive to do it.
I believe it's data only.Will the eSata port also power the drive or do I need a USB/Molex adapter?
