how would you guys rate an intel core i7 950 in todays games, and applications. what would its equal be in todays intel and amd processors
That really depends on the bit bus of you GPU. I had an R9 290 briefly that has a 512-bit RAM bus, so it uses the RAM much more efficiently than an HD 5770 1GB with a 128-bit. I bet if you could cut down the RAM of a 290X to 1GB RAM, it would still max out BF4 - because it basically needs less RAM to do the same.But not all game can be setting to max on 1 GB and work well. Just like BF 4 that need at least 2 GB to do maxed setting video.
not true.
1. because then they wouldn't put 4gb on it
  because actual real world performance is all that matters in marketing
  (NVIDIA had 3GB on their top card before the 290X hit the streets)
 (NVIDIA had 3GB on their top card before the 290X hit the streets)Sort of what I was trying to get through. There are obviously too many variables to make it an apples to apples comparison, but yeah.On a really basic level you should observe similar transfer rates between 2 GHz 512-bit DDR as you would with 4 GHz 256-bit DDR.
