Thinking Of Buying New Desktop...
What are you looking to do with it? That Asus one is much more powerful than the BestBuy one, but if all you want is a cheap system to surf the web and stream music, it's overkill.
Is the computer in your sig yours? It's better than both the PCs you listed. As imsati said, the Asus PC is a lot more powerful, however it doesn't tell us which specific video card it comes with.
Do you have a budget? Would you be open to building it yourself?
I have about 1,000. But the one in my Sig is gonna be my YouTube stuff.
Just so I understand you right, the new build is completely separate from the one in your sig, correct?
Would you be open to having us price out parts for <$1,000? You'd then build it yourself.
What do u use the new pc for?
Is ur $1000 budget include monitor?
Do u want self assemble or pre built?
