New card
The VCR King
Well-Known Member
I want to put in a new Radeon 6950 card where the one that died was so I can crossfire again. Since my computer has the drivers for a dual-card setup installed anyways, shouldn't I just be able to pop in the new card and it'll work, because its another 6950 in a slot with dual card drivers already set to it?
THIS:
http://www.amazon.com/HIS-Radeon-25...id=1418349105&sr=8-4&keywords=AMD+Radeon+6950
will work with
THIS:
right?
Yes. Brands don't matter. As long as it's a 6950 it'll work.
P.S.
Even if you didn't crossfire before, driver doesn't matter. Crossfire is just an option and the option would have been installed anyway :rolleyes:
^That bothered me. That's why I said it.
On Amazon I only found that HIS card and some Sapphires. Anyone know any other brands of 6950s that are sold elsewhere?
EDIT: nevermind. Found some on Google Shop.
The brand itself doesn't really matter, the only difference between models for the most part are any factory overclock that is applied and the type of cooler being used.
