Hi, I bought these cards about a year ago; one 1GB XFX HD 6870 and a 2GB XFX HD 6870. Ever since i've been running them in crossfire i've been having a problem with display driver crashes which happen on startup (sometimes BSOD caused by atikmpag.sys). This does not happen when gaming only upon startup. I've tried everything to fix it; new and old drivers, wiping the drivers in safe mode and reinstalling them, reinstalling windows fresh, installing windows 8 64bit instead of windows 7 64bit, applying the microsoft fix it (TdrDelay fix) and also re-extracting the atikmpag.sy_ files manually and replacing but nothing has worked. These crashes are nothing more than a temporary nuisance and they only happen upon startup after the system has been powered off say overnight. I got over this problem but now I want to sell the cards and need to know if I can sell them as working and know that they wont be returned to me by an angry customer so I come to you guys in search of ways to foolproof fault test them to prove that the problem is not that GPU and so I can sell both cards as working in order to upgrade to something better. I've already ran furmark stability tests and they run without a hitch with a min FPS of 140, allbeit a little hot.
Any help is greatly appreciated, Thank you!
