New Budget Pc
Himynameisben
**CPU** | [Intel Core i5-4430 3.0GHz Quad-Core Processor]
**Motherboard** | [Gigabyte GA-Z97-HD3 ATX LGA1150 Motherboard]
**Memory** | G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
**Storage** | WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache
**Video Card** | [\*XFX Radeon R9 280X 3GB Double Dissipation Video card
**Case** | [Cougar Solution (Black) ATX Mid Tower Case]
**Power Supply** | [Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply]
**Operating System** | [Microsoft Windows 8 (OEM) (64-bit)]
| [Cooler Master CM Storm Devastator - OEM Wired Gaming Keyboard
This is my first pc build and I was wondering if this would be a good set up. If there is anything wrong with it can you please tell me, my budget can't go much higher then this. Also what fps could I get in games like Bf4 and CSGO on all ultra or high? Also I have a monitor already.
Thank you
My new build
PCPartPicker part list: http://pcpartpicker.com/p/NpRxkL
Price breakdown by merchant: http://pcpartpicker.com/p/NpRxkL/by_merchant/
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor ($187.99 @ SuperBiiz)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard ($96.48 @ Newegg)
Memory: Team Elite Plus 8GB (2 x 4GB) DDR3-1600 Memory ($65.98 @ Newegg)
Storage: Western Digital Caviar Blue 750GB 3.5" 7200RPM Internal Hard Drive ($56.00 @ Amazon)
Video Card: XFX Radeon R9 280X 3GB Double Dissipation Video Card ($204.99 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($49.99 @ Newegg)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($89.98 @ OutletPC)
Keyboard: Cooler Master CM Storm Devastator - OEM Wired Gaming Keyboard w/Optical Mouse ($17.99 @ Newegg)
Other: DIYPC Ranger-R8-G Black/Green USB 3.0 ATX Mid Tower Gaming Computer Case with 3 x Green Fans (1 x 140mm LED Fan x side, 1x120mm LED Fan x front, 1 x 120mm fan x rear) ($49.89)
Total: $819.29
Thanks for the help I have changed somethings in my build and this my my current one. Is it good? Same thing don't need a CD Drive.
Total: $819.29
Total: $819.29
Just tell us your budget, that way we can put together a build for you
Ninja: My guess is low 800's...
Ben: here's a build that's a bit better quality then what you have listed. It'll cost a bit more with keyboard/mouse and OS, but you can always run the Windows 10 preview for free, until it comes out next year. http://pcpartpicker.com/p/tGYKxr
Feel free to keep all you have, I added the better processor, and the pre-overclocked 280X from XFX and a 1TB drive for $5 less. Then I just changed the the Mobo and case up.
280X is better then the GTX 760. Great mobo. If you do have the extra money, get 2133MHz RAM like Ninja said, though it won't make too much of a difference from 1866 unless you're rendering and such.
