Tooda lama
Thanks everyone ill have to save up again.
I just had a thought. I remember a nice laptop I had back then which was a Dell C610. They can be had for around $60 on ebay. However, the only game you could play on it is Diablo 2. Heros 2 requires at least 2GHz dual core and I'm sure Heros 3 requires the same if not more horse power.
The Dell C610 was a very popular laptop back in the day and it should work fine on the Internet. My Dell Mini 9 netbook is only a 1.6 GHz CPU and I can watch YouTube on it. Although it is a little slow and I guess that is due to the speed of the motherboard.
http://www.ebay.com/itm/Dell-Latitu...27220109?pt=Laptops_Nov05&hash=item27f5c78c8d
This one needs a new battery which could be found on ebay. http://www.ebay.com/itm/Dell-Latitu...98252865?pt=Laptops_Nov05&hash=item2c7e57ee41
Needs battery. http://www.ebay.com/itm/Dell-Latitu...98250481?pt=Laptops_Nov05&hash=item2c7e57e4f1
Eraser head problem, but you can use the track pad. http://www.ebay.com/itm/Dell-Latitu...74104591?pt=Laptops_Nov05&hash=item463141c50f
You will need to install XP on this one. http://www.ebay.com/itm/Dell-Latitu...22496245?pt=Laptops_Nov05&hash=item5662aa01f5
There are others but they go up to $70+ which I think is ridiculous. Just go to ebay and search for Dell C610.
i like the one in the second link
cause the sellers about 30 minutes from where i live. But, is it safe to buy a computer off ebay?
One last question would a dell latitude c640. 2.4 ghz windows xp be good?
What? An i5 is hardly necessary for Diablo 2 or anything around that age or older. That 640 is good for games into ~2002. Heck it's even got a radeon mobile GPU, not some Intel "extreme" graphics.Nope. Sorry. Save up to $300 or so, and you'll be able to get a used laptop with an i5 and HD 3000 graphics. It will play any older game just fine.
I would recommend a Dell Latitude E6420 from eBay.
This.FWIW HoMM 2 and 3 will run just just fine on a 233MHz Pentium 2 machine with little ram (64MB for Win98 did fine), those games aren't exactly CPU intensive. The 2GHz dual-core requirement is absolute bollocks, unless we're talking about completely different games. Diablo 2 isn't exactly a resource hog either, battle.net has Pentium 233, 32MB RAM and a Direct X graphics card as minimum requirements. These are really old games, remember.
You might be better off asking your friends/family if they have old, crap Win98/ME-era machines hanging around that they want to get rid of. Any new netbook will have more than enough grunt to run HoMM2&3 and Diablo II, however you might run into compatibility problems with a new OS. I can confirm that HoMM3 works fine on Windows 8.1, though.
EDIT: If all you want to do is play some oldschool games (i.e. no internet, or only browsing a handful of trusted sites), don't worry about getting yourself an anti-virus program.
