Logitech Anywhere MX mouse
storp
That I do like, the way it fits in the palm, the way the curser smoothly moves. But there is one problem.
These only seem to last a little over a year. Then it's kaput.
Any better mouses out there for around $65 that actually lasts?
What is your main use for the mouse? Gaming, etc.
It does seem odd that you've had 2+ Logitech MX Anywheres that only lasted ~1 year. Are you hard on your stuff? Logitech stuff is usually quite high quality.
Nothing to do with the mouse, but it should be fixed. Do you use a CRT or LCD?
As for a Mouse, do you want wired or wireless?
Apologize for the DP - but I just got an Anywhere MX mouse replaced, under warranty.
The replacement is stuttering and jumpy all over the place.
Wondering if they gave me a refurb - it did come packaged in a brown box instead of the usual (with a promo sticker on the inside telling of the advantages of such a box over printed material, etc...)
Underside 4 skids do seem to have some barely discernible surface scratches, like someone had buffed the surfaces. Not sure if this was from wear or not, never looked at store-bought ones this up close.
Either it is a reburb that doesn't perform as it should, or there is something else going on.
Could it be anything related with video processing? I don't have a vid card but instead rely on my Intel Core I5-4670K LGA 1150
Seems the prior same mouse would have shown such symptoms if this was the case, before it failed.
