Gaming Teen
The Gigabyte GA-F2A58M-HD2 Micro ATX FM2+ Motherboard worth the buy? I don't know about motherbored's to much and would like advice.
Really wouldn't recommend that one. Would do either of these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128689
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128659
I use the bottom link all the time.
Yeah, you would need the F6 bios before being able to use that cpu. But any board you pick would most likely need a bios update. Any local computer repair shop could update the bios for you with a minimal fee of course.
You have to have a supported processor installed in order to update bios.
Supported processor means a processor that currently installed bios will work with. Here is the supported processors for that board.
http://www.gigabyte.us/support-downloads/cpu-support-popup.aspx?pid=4716
I just built one and gave it to the owner a little bit ago. I could have checked what bios revision is installed. Like I said, any board you would get will most likely need a bios update to support the Kaveri's.
I use the 5800k cpu for all my client builds.
John is there a way to pm you later in the future if i need to.
Any way to post fast?
Any way thanks for the help/advice/information.
