Tell me what videya card to buy
Tuffie
In this thread here I describe a problem I'm having that I cannot seem to find a solution to: http://www.computerforum.com/233153-one-monitor-works-another-doesnt.html
After reformatting and clean installing windows today I now believe that it is my video card that is failing and hope that replacing it will resolve the issues that I am having..!
My system is:
i3-2120 @ 3.30 GHz
4.00GB RAM
Nvidia GTX 460
I'm having difficulty comparing my current video card to the current line up which is making identifying one slightly difficult.
I know I'd like 2 x DVI outputs and 1 x HDMI (anysize) and that I'm happy with the performance that the 460 is giving me and I don't want to spend too much on it.
The people who I'd like to purchase from are either Umart or MSY preferably UMART as I can pick it up they're prices on current video cards are below:
http://www.umart.com.au/umart1/pro/products_list_GPU.phtml?id=10&bid=6&id2=425
http://cdn.msy.com.au/Parts/PARTS.pdf
Whats your budget?
Roughly $140.00 I'd prefer to be paying the least for the most however if you know what I mean.
Like if there was a HUGE performance increase for spending an extra $25 dollars, I would do that, but if there was little extra to be had between spending $100 or $150 I would definitely want to be spending as least as possible.
Wow Tuffie where have you been hiding? :cool:
Maate I've always been here.. Lurkin. :P
If anyone has any ideas as to what the issue is here, let me know! I sure hope buying new GPU is the way to go
The R9 270X is about $160 but has everything you what.. Below this is the R7 260X and also the GTX 750ti.. Not sure what kind of outputs they have though..
Ended up getting a GTX 750 for $155.00. Fixed the issue promptly happy with performance. Thanks for the replies.
