Chromebook WiFi Issues !
Electricfat
Hello lads, I have an issue. For school we are given the best laptop in the world the Samsung Chromebook XE303C12 (sarcasm) and It has been fine for the last year or so and has started to give me some issues. The issue I have is when I am using my Chromebook the internet connection speed starts to go very slow and then it just disconnects ! So then I am just like fine I will just go an reconnect, when I go to do that my bloody WiFi has simply disappeared, I can find all my neighbor's WiFi but I can't find mine. To resolve this issue I must restart my Chromebook for the problem to once start again later anyway. I was thinking it was some hardware fault so I went to school to do some experimenting but at school there is no bloody problems ! I have tried resetting my router to see if it was a problem at my end but nothing works ! So what is your diagnosis to this problem and help me resolve this problem ?
--EDIT--
My Chromebook is managed by my school if that does anything ?
Do you have other devices at home that connect wireless and are they having any problems?
Since it works OK at school but has problems at home I would suspect your router or the environment. There may be another device that is interfering with your wifi signal so try changing the channel the router is using. Typical router default config is to set the channel to Auto but you can override that and set a specific channel.
No, well none besides my iPad which for some reason keeps on telling me that my WiFi password is wrong even though I enter the correct password ! Although its apparently just some glitch from apples new OS.
