Humans and computers do not function the same way.
I'd bet my life that if you had same ati card without fan, my card will last longer.
Facedesk.
Make sure your card gets the appropriate 8 hours of sleep every night too![]()
You might just be getting low framerate in some intense situations. What exactly is happening?
Facedesk.
You could argue that the fan would be a more likely culprit to fail before the card does. If paired with an insufficiently-sized heatsink for passive cooling, the card with the fan would thermal throttle and overheat while the passive one would exhibit no heat related issues from losing a fan.
You talk like a Hardware seller!
It honestly sounds like you have too much crap running in the background. Have you done some house cleaning so you don't have useless junk running in the background?
Don't forget dust bunnies might be hopping around. They tend to be small.
This thread is golden.
I'd bet you my life that isn't even remotely what I was referring to. You said the card was faster. It's not.
YES it will run quieter and cooler (and thus possibly LONGER) but it will not run any faster simply because you put a fan next to it. Also longevity on a lower end card is pretty much skys the limit. With no moving parts it should theoretically last forever, fan or not. You only really need to worry about longevity on cards that are prone to throwing off a lot of heat and use fans to cool it, like my 7970.
My mistake, i meant that video would be more stable if it's not over heating
