Can't get rid of this 'Binkiland' crap.
NLAlston
I don't how/why this mess (Binkiland) was contracted, but I cannot uninstall it - no matter HOW many times I have tried. This file (or whatever it is) can be seen as the last icon in the attached screenshot. AVG notification, which pops up on each attempt to uninstall the concerned file, can also be seen at the bottom, right side of what I have attached. How can I get rid of this? Or must I undergo yet another formatting episode?
Advanced thanks, for any help with this matter.
Well, I don't know much more than the average person - when it comes to computers - but I think that I may have overcome that dilemma.
Not knowing what else to try to do, I went into the running processes, within the 'Windows Task Manager' area. There, I sought for something which made any kind of reference to what was bothering me, and I stopped that process. The very next time that I journeyed back to the Control Panel's 'Uninstall A Program' section, I noticed that the icon, which referenced what I'd wished to uninstall, was no longer there.
Has this been taken care of yet? If not do the following.
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
