finsfree
I have discovered that my router that I using, that was provide by my ISP, is a slow turtle and I want to upgrade. I'll be putting the old router into bridge mode and adding a new/upgraded router to the network.
After doing some research I have discovered that there is a new technology of wireless routers called "AC" and after searching for these AC routers I have found out that these routers are not cheap, at lease the "good ones" aren't. Some are like in the $300.00 range
What router is the best bang for the buck?
I want gigabit speed LAN ports and wireless 802.11ac (5GHz) technology.
Thanks for the help
Thanks for the help
