Hi there.
I recently bought a new laptop because my old one was pretty dated, its an ASUS xF553MA which is pretty good for what I use it for.
However I've noticed that the hard drive is constantly powering down and then back up, literally every 20 - 30 seconds I hear it power back up which is annoying, especially when it's quiet.
I know what you're thinking - first thing I did was check the power options out only to find it's set to sleep after 10 minutes; 20 plugged in. Also it makes no difference if it's plugged in or not since it acts exactly the same regardless. The only way to stop it is to do something that would use more drive activity, like browsing the net or something, if I'm just coding or writing a document it drives me mental hearing it start up all the time, powering down is fine since it's a gradual process.
The drive itself is a 1TB SATA, 5400 but I'm not sure what brand or model. I'm guessing it's some 'economical' one that saves power at every opportunity but it's pretty annoying listening to it constantly power back up, I wouldn't mind if it wasn't so constant. I did update the BIOS not long after I got it since there were quite a few versions that had gone by.
Anybody know how to stop this?
