Is there any replacement for this?
LauncH
Is there any replacement for the "Gigabyte Radeon R9 280X" that goes along with my current build?
PSU Corsair CX 600W, 80 Plus Bronze
ASUS M5A97 LE R2.0 SocketAM3
AMD FX-8320
WD Blue 3.5'' 1TB SATA3
DDR3 SODIMM Crucial 4GB 1600MHz 2x
Cooler Master Hyper 212 Evo
Enermax OSTROG without PSU
Would this change the performance? Gigabyte Radeon R9 280 3GB GDDR5
A standard 280 is slightly slower.
What exactly are you trying to do?
My internet store, where I bought things, is out of stock. Have no idea when the new load is coming. Don't really want to wait, if there's another way. Would you say I should buy it or wait?
If you're in the US then Newegg or Amazon are your best bets. What country are you in?
I am from Lithuania. I was away for a month, and when I came back, my store was out of stock. Could you please tell me is it worth it? Or maybe this? SAPPHIRE VAPOR-X R9 280X 3GB
I personally prefer Nvidia so I'm going to recommend a GTX 770 or 780. Same performance if not better, especially with the 780. As you can see in my signature I'm using a GTX 770 and it runs every game at max settings.
