Building first computer
loltraktor
I am once again planning on building a computer. A couple of years ago I had the same idea, but due to life changes that never happened. So this will be my first build. I am still pretty much illiterate when it comes to computers, but am interested in building rather than buying a gaming rig.
I will use it mainly for gaming and, secondarily, work. Anyway I have updated by parts list. I was wondering if all these parts would work together. My budget is $1500.
Thanks for your input, I will keep you all updated as to how it goes, LT.
Intel Core i7-4790K 4.0GHz LGA 1150 (may change to i5 4690)
ASRock Z97 Extreme6/ac LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Western Digital Blue WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive Bare Drive
Samsung 850 Pro 256GB 2.5" 256G SATA III Internal SSD 3-D 3D Vertical Solid State Drive MZ-7KE256BW with OEM USB 3.0 Adapter and USB Cable
MSI GeForce GTX 970 Gaming 4GB GDDR5 Video Card
EVGA SuperNOVA 850 G2 220-G2-0850-XR 850W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Full Modular Power Supply Intel 4th Gen CPU Compatible 10 Year Warranty
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Model #:RR-B10-212P-G1
LITE-ON 24X DVD Writer Internal Model IHAS324
G.SKILL Ares Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-8GAB
Model #:F3-1600C9D-8GAB
NZXT Phantom 530 Black ATX Full Tower Computer Case Includes 1 x 200mm Front, 1 x 140mm Rear 2 x USB 3.0 Fan Controller
Cisco, thanks. I will check it out.
It's not out yet, it's the new Broadwell-based CPU. It's going to push your budget higher as the motherboard and RAM are more expensive.
8GB of RAM is considered low for a high end PC these days, I'd look at 16GB.
