USB Flash Drive Not Working?
finsfree
My PC is running Windows 7 Pro.
After I plugged in my USB flash drive I get a pop up in the task bar that says, "installing drivers" then says, "your device is ready to be used" or something along those lines.
Under "Computer" the USB flash drive doesn't show. Next I looked in Disk Management and I can see it there, but when I right click it to either format or change drive letter it won't let me.
I get a message stating, "The operation failed to complete because the Disk Management console view is not up-to-date. Refresh the view by using the refresh task. If the problem persist close the Disk Management console, then restart Disk Management or restart the computer."
Time for some general clean up of your system. I've ran into this issue so many times on clients computers. After cleaning, it works fine.
1. run Ccleaner
2. Run the following malware scanners.
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
So in your original thread asking for help, please give us a short description of what the problem is and then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
something has happened to this flash drive
It is for sure that something has happened to this flash drive either it's defective or something changed the condition of the drive but clearly the computers ackknowledge that something is connected when the drive is pluged in. I'm not certian that this can help but if the partition in the drive has been altered then you may be able to get the data off with this free software.
http://www.cgsecurity.org/wiki/TestDisk
