Virus!
Faurholdt
Some months ago I downloaded a free injector for arma3... I was dumb, I know. And now it pops up every time i start my pc up it says something like this: "Allow changes on computer" it has "Yes" and "No" and it pops up with a cmd for around 1 second max? I've tried to delete all of it with AVG but it stills keeps comming up. Help me please. :)
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
So in your original thread asking for help, please give us a short description of what the problem is and then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
Run Autoruns and post your ARN file. Use Mediafire, Drop box or Box to upload.
This is just an injector to inject a hack?
