Use disk management to see if there is a recovery partition.  You should be able to use the link here.  Just list what the names of the partitions are and what space is used and how much is free for each partition.
original 8 64 bit ISO file -
http://care.dlservice.microsoft.com...ISE_EVAL_EN-US-HRM_CENA_X64FREE_EN-US_DV5.ISO
However, I don't know when you upgraded to 10 if it replaced windows 8 key with a generic 10 key.  If so then there is no way to find out your windows 8 key and you would need to order recovery cd's.
     i used belarc advisor to take full profile of my pc , details are below
Computer Profile Summary
Computer Name:  Dan-B24 (in WORKGROUP)
Profile Date:  15 July 2015 05:38:02
Advisor Version:  8.4
Windows Logon:  Dan
 Click to try our Commercial and Government Products
Operating System   System Model
Windows 8.1 Professional (x64) (build 9600)
Install Language: English (United States)
System Locale: English (United States)
Installed: 10-07-2015 01:21:25
Boot Mode: Legacy BIOS in UEFI (Secure Boot not supported)   LENOVO 10114 Lenovo C245
System Serial Number: CS00497103
Chassis Serial Number: CS00497103
Enclosure Type: All-in-One
Processor a   Main Circuit Board b
1.40 gigahertz AMD E1-1200 APU with Radeon HD Graphics
128 kilobyte primary memory cache
1024 kilobyte secondary memory cache
64-bit ready
Multi-core (2 total)
Not hyper-threaded   Board: LENOVO Win8 STD EM DPK IPG
Bus Clock: 100 megahertz
UEFI: LENOVO I3KT18AUS 11/02/2012
Drives   Memory Modules c,d
499.27 Gigabytes Usable Hard Drive Capacity
396.77 Gigabytes Hard Drive Free Space
HL-DT-ST DVDRAM GT80N [Optical drive]
ST500DM002-1BD142 [Hard drive] (500.11 GB) -- drive 0, s/n W2ARWKNA, rev KC65, SMART Status: Healthy   3682 Megabytes Usable Installed Memory
Slot 'DIMM 0' has 4096 MB (serial number E2500189)
Slot 'DIMM 1' is Empty
	  Local Drive Volumes
c: (NTFS on drive 0) * 214.28 GB 111.92 GB free
e: (NTFS on drive 0) 284.99 GB 284.85 GB free
* Operating System is installed on c:
	  Network Drives
	  None discovered
Users (mouse over user name for details)   Printers
local user accounts last logon
 Dan  15-07-2015 05:29:50 (admin)
local system accounts
 Administrator  18-03-2014 16:09:11 (admin)
 DefaultAccount never
 Guest never
 HomeGroupUser$ never
DISABLED Marks a disabled account;   LOCKED OUT Marks a locked account
Microsoft Print To PDF on PORTPROMPT:
Microsoft Shared Fax Driver on SHRFAX:
Microsoft XPS Document Writer v4 on PORTPROMPT:
Controllers   Display
Standard SATA AHCI Controller   AMD Radeon HD 7310 Graphics [Display adapter]
Lenovo AIO PC [Monitor] (18.5"vis, January 2012)
Bus Adapters   Multimedia
Microsoft Storage Spaces Controller
AMD USB 3.0 eXtensible Host Controller - 0.96 (Microsoft)
Standard Enhanced PCI to USB Host Controller (2x)
Standard OpenHCD USB Host Controller (3x)   AMD High Definition Audio Device
Lenovo USB2.0 Audio
Realtek High Definition Audio
Virus Protection [Back to Top]   Group Policies
Windows Defender Version 4.8.10074.0
    Scan Engine Version 1.1.11804.0
    Virus Definitions Version 14-07-2015 Rev 1.201.1772.0
    Last Disk Scan on 15 July 2015 03:22:20
    Realtime File Scanning On
   None discovered
Communications   Other Devices
↓ 1x1 11b/g/n Wireless LAN PCI Express Half Mini Card Adapter
 Status:  Not connected to a network
 Dhcp Server:  none responded
 Physical Address:  20:16
8
A:E4:EF
Microsoft ISATAP Adapter
Microsoft Kernel Debug Network Adapter
Microsoft Teredo Tunneling Adapter
↓ Microsoft Wi-Fi Direct Virtual Adapter
8
A:E4:EF
↑ Realtek PCIe GBE Family Controller
 primary   Auto IP Address:  192.168.0.102 / 24
 Gateway:  192.168.0.1
 Dhcp Server:  192.168.0.1
 Physical Address:  20:89:84:47:70:CB
 Connection Speed:  100 Mbps
Networking Dns Server:  192.168.0.1
   Microphone (Lenovo USB2.0 Audio)
Speakers (Realtek High Definition Audio)
HID-compliant consumer control device
HID-compliant system controller
USB Input Device (3x)
Lenovo USB2.0 UVC Camera
HID Keyboard Device
Standard PS/2 Keyboard
HID-compliant mouse
Realtek PCIE CardReader
Fax
Print as a PDF
Root Print Queue
SDA Standard Compliant SD Host Controller
Microsoft GS Wavetable Synth
Microsoft IPv4 IPv6 Transition Adapter Bus
Microsoft Radio Device Enumeration Bus
Wi-Fi
USB Composite Device (2x)
USB Root Hub (5x)
USB Root Hub (xHCI)
Generic volume shadow copy
USB Storage Use in past 30 Days (mouse over last used for details)   Hosted Virtual Machines (mouse over name for details)
None discovered   None discovered
 See your entire network map...
 click for Belarc's System Management products
Network Map (mouse over IP address for physical address) [Back to Top]
IP
Device Type
Device Details
Device Roles
192.168.0.1  Router D-Link DHCP Server, Gateway, Domain Name Server, Web Server
192.168.0.101   Physical Address E4:90:7E:83:43:3B
192.168.0.102  Windows Workstation Dan-b24 (in WORKGROUP) Web Server
192.168.0.107   Physical Address 6C:2F:2C:59:4D:B5
192.168.0.108   Physical Address DC:CE:BC:98:9B:01
 Find your security vulnerabilities...
Missing Security Updates new – for Adobe, Apple, Java, Microsoft and more [Back to Top]
 Hotfixes from Microsoft Update (agent version 10.0.10074.0) install automatically.
 These security updates apply to this computer but are not currently installed (using Advisor definitions version 2015.7.8.6), according to the 06/09/2015 Microsoft Security Bulletin Summary and bulletins from other vendors. Note: Security benchmarks require that Critical and Important severity security updates must be installed.
Hotfix Id
Severity
Description (click to see security bulletin)
APSB15-16 Important  Adobe Flash Player security update for Flash Player 17.0.0.188 ActiveX 64-bit
APSB15-16 Important  Adobe Flash Player security update for Flash Player 17.0.0.188 ActiveX 32-bit
Q2538243 Important  Microsoft security update (KB2538243)
Q2919355 Critical  Microsoft security update (KB2919355)
 Manage all your software licenses...
Software Licenses [Back to Top]
Belarc - Advisor 1536a118
Microsoft - PowerShell 89383-100-0001260-04309
Microsoft - Windows 8.1 Professional (x64) 00261-50000-00000-AA406 (Key: none activated)
 Find unused software and reduce licensing costs...
Software Versions & Usage (mouse over i for details, click i for location) [Back to Top]
   ı i  Adobe Systems - Flash Player Update Service Version 18,0,0,203
     i  Adobe Systems - Shockwave Flash Version 17,0,0,188 (32/64-bit)
   ı i  Advanced Micro Devices - AMD Fuel Service Version 1.0.0.0 (64-bit)
   ı i  Advanced Micro Devices - Catalyst Control Center Version 3.5.0.0 (64-bit)
   ı i  AMD - External Events Version 6.14.11.1196 (64-bit)
   ı i  ATI Technologies - Catalyst Control Center Version 4.5.0.0
   ı i  Belarc - Advisor Version 8.4
     i  Check Point Software Technologies - VPN Version 1.0.0.1
     i  Dell SonicWALL - SonicWALL Mobile Connect Version 1.0.0.8
     i  F5 Networks - VPN Version 1.0.0.11
   ı i  Google - Chrome Version 43.0.2357.134
   ı i  Google - Update Version 1.3.27.5
   ı i  House of Life - BitLord Version 2.4.1-293
   ı i  IncrediMail - Guardbox Version 1.11.0.5
     i  Juniper Networks - Junos Pulse Version 1.0.0.206
     i  Microsoft - .NET Framework Version 3.0.6920.8663
     i  Microsoft - .NET Framework Version 4.0.41210.0 (32/64-bit)
     i  Microsoft - .NET Framework Version 4.6.57.0
     i  Microsoft - AAD Token Broker Plugin Version 10.0.10074.0 (64-bit)
     i  Microsoft - Antimalware Service Executable Version 4.8.10074.0 (64-bit)
     i  Microsoft - Cloud Experience Host Version 10.0.10074.0
     i  Microsoft - Contact Support Version 10.0.2.0
     i  Microsoft - DevicesFlow Version 6.2.0.0
     i  Microsoft - Email and accounts Version 10.0.10074.0
     i  Microsoft - Family Version 10.0.10074.0
     i  Microsoft - Games Version 2.0.139.0 (64-bit)
     i  Microsoft - Get started Version 1.9.2.0 (64-bit)
     i  Microsoft - Insider Hub Version 15.3.30.1 (64-bit)
     i  Microsoft - Internet Explorer Version 11.0.10074.0 (32/64-bit)
     i  Microsoft - Mail and Calendar Version 17.4125.42001.0 (64-bit)
     i  Microsoft - MiracastView Version 6.3.0.0
     i  Microsoft - MSN Food & Drink Version 3.0.4.315 (64-bit)
     i  Microsoft - MSN Health & Fitness Version 3.0.4.315 (64-bit)
     i  Microsoft - MSN Money Version 4.3.63.0
     i  Microsoft - MSN Sports Version 4.3.63.0
     i  Microsoft - MSN Travel Version 3.0.4.318 (64-bit)
     i  Microsoft - MSN Weather Version 4.3.63.0
     i  Microsoft - MtcUvc Version 6.2.0.0
     i  Microsoft - Music Preview Version 3.6.9991.0 (64-bit)
     i  Microsoft - Music Version 2.6.672.0 (64-bit)
   ı i  Microsoft - OneDrive Version 17.3.5860.0512      i  Microsoft - OneNote Version 17.4027.10061.0 (64-bit)
     i  Microsoft - People Version 1.0.10117.0 (64-bit)
     i  Microsoft - Photos Version 15.420.14330.0 (64-bit)
     i  Microsoft - PrintDialog Version 6.2.0.0
     i  Microsoft - PrintDialog3D Version 1.0.0.0
     i  Microsoft - Project Spartan Version 0.11.10074.0
     i  Microsoft - Reader Version 6.3.9654.17499 (64-bit)
     i  Microsoft - Search Version 1.4.4.120 (64-bit)
     i  Microsoft - Settings Version 6.2.0.0
     i  Microsoft - Store (Beta) Version 2015.5.6.0 (64-bit)
     i  Microsoft - Store Version 1.0.0.0
     i  Microsoft - Video Preview Version 3.6.9991.0 (64-bit)
     i  Microsoft - Video Version 2.6.440.0 (64-bit)
     i  Microsoft - Windows Alarms & Clock Version 10.1504.23000.0 (64-bit)
     i  Microsoft - Windows Calculator Version 10.1503.31000.0 (64-bit)
     i  Microsoft - Windows Camera Version 5.5.6.0 (64-bit)
     i  Microsoft - Windows Default Lock Screen Version 1.0.0.0 (64-bit)
     i  Microsoft - Windows Feedback Version 10.0.10074.0 (64-bit)
     i  Microsoft - Windows Installer - Unicode Version 5.0.10074.0 (32/64-bit)
     i  Microsoft - Windows Live Version 17.3.4726.0226
     i  Microsoft - Windows Maps Version 4.1505.50510.0 (64-bit)
     i  Microsoft - Windows Media Player Version 12.0.10074.0 (32/64-bit)
     i  Microsoft - Windows Reading List Version 6.3.9654.20540 (64-bit)
     i  Microsoft - Windows Scan Version 6.3.9654.17133 (64-bit)
     i  Microsoft - Windows Script Host Version 5.12.10074.0 (32/64-bit)
   ı i  Microsoft - Windows Search Version 7.0.10074.0 (32/64-bit)
     i  Microsoft - Windows Shell Experience Version 10.0.10074.0
     i  Microsoft - Windows Spotlight Version 10.0.10074.0
     i  Microsoft - Windows Voice Recorder Version 10.1504.6000.0 (64-bit)
     i  Microsoft Studios - Solitaire Collection Preview Version 3.0.4031.0
   ı i  No Company Name - Popcorn Time 0.3.8-0
     i  No Company Name - Popcorn Time.exe
     i  No Company Name - Sensor Data Service (64-bit)
   ı i  Opera Software - Internet Browser Version 30.0.1835.125
   ı i  Realtek Semiconductor - HD Audio Background Process Version 1, 0, 0, 220 (64-bit)
   ı i  Realtek Semiconductor - HD Audio Manager Version 1, 0, 0, 967 (64-bit)
     i  Skype - Skype Version 3.1.0.1007
   ı i  Skype Technologies - Skype Updater Service Version 7.0
   ı i  Skype Technologies - Skype Version 7.6
   ı i  Tonec - Internet Download Manager (IDM) Version 6, 23, 14, 2
   ı i  VideoLAN - VLC media player Version 2,2,1,0
i  Mouse over to see details, click to see where software is installed.
   ı  Marks software last used within the past 7 days.
  ıı  Marks software last used within the past 90 days, but over 7 days ago.
 ııı  Marks software last used within the past year, but over 90 days ago.
ıııı  Marks software last used over 1 year ago.
  Unmarked software lacks the data to determine last use.
 Audit your security posture...
Installed Microsoft Hotfixes [Back to Top]
Click here to see all installed hotfixes.
a. Processor clock speed is measured at computer start-up, and on laptops may be impacted by power option settings.
b. Data may be transferred on the bus at one, two, or four times the Bus Clock rate.
c. Memory slot contents may not add up to Installed Memory if some memory is not recognized by Windows.
d. Memory slot contents is reported by the motherboard BIOS. Contact system vendor if slot contents are wrong.
e. This may be the manufacturer's factory installed product key rather than yours. You can change it to your product key using the procedure at
http://www.belarc.com/msproductkeys.html.
f. The full product key is not stored on this computer. However, the characters shown uniquely identify your product key.
g. You can have Windows save the full product key using the procedure at
 Copyright 2000-13, Belarc, Inc. All rights reserved.
Legal notice. U.S. Patents 5665951, 6085229 and Patents pending.
it shows i installed windows 10 on 10-07-2015 , also observe that it says i have windows 8.1 while i am actually on windows 10 build 10074 .
