kam
Hi all
So basically yesterday I was on my computer when I heard a sound that sounded like a fan was rubbing something. So as I got up to turn on my light and crack my case open, I heard crackling/banging sounds and I saw sparks coming from inside my computer. I stepped back and then it stopped, my computer shut down a and I started to smell a burning scent...I quickly ran over and unplugged my PSU and waited for a bit just incase there was actually something that could harm me exposed inside the case. So about 10 minutes after I just said f*** it and I unplugged it and opened it up. My fear was that my GPU got fried by a wire getting caught up in a fan on the GPU and it going haywire and exploding. As I opened it I didn't see any immediate damage, no wires were broken, the cpu fan wire wasn't broken or anything, my GPU looked fine so I naturally put my hand on the case and PSU to discharge myself and the PSU was very hot. I unscrewed it and took it out and noticed pretty much straight away the the burning scent was coming from inside the PSU. I didn't want to open it because I'm no electrician and you should never open one if you have no clue what you're doing (me) so I gave it a shake to listen if anything was loose inside and indeed there was. I tried to empty whatever was making the rattling sound but it wasnt coming out so I shined a light inside and saw a small piece of metal that looked like it broke off and my guess is that it touched an amp or something which shortened out the PSU and fried it completely. So the PSU is in the trash and my question is, is there a possibility that my other hardware could've got fried? I.e motherboard, GPU or CPU? I know the ram and cpu are pretty much a 'lifetime no break' thing so I'm not too worried about them, but what about my mobo and GPU? If anyone knows anything about this kind of stuff I'd be happy to hear because I don't want to go and buy a new PSU to find out my whole system is dead.
Thanks all!
Thanks all!
