Windows 10 Upgrade Issues
Noober
Hey! need some help... I am using a laptop : Asus x550c. when i had windows 8.1, everything worked just fine. i could work with photoshop and even play gta IV (this is not a high end pc). Since i got windows 10 (this night) i can't even browse the web. I never had problems with overheating. even while playing games, it wouldn't be hot. mildly warm i'd say. And now even if i am doing nothing, it's supper laggy, fan starts working like crazy, after 10min it's so hot, that even the keyboard would stop responding. I am writting this comment from my phone since, appearantly, My pc is not capable of even opening the forum... what could be wrong? have any tips? I am planing of cleaning it later today.
Found out why... Father accidentally installed maybe a hundred viruses and Trojans.... Still can't get rid of them all.. The main problem was CPUminer. Now it's not so hot. yet 26% of cpu is still in use during all times.
Start here and run the programs and post the logs.
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
Reinstall WIndows.
Reset your PC in the Windows options should accomplish the same effect as a fresh install without being quite so difficult. Just make sure you don't have it set to save any of your files or settings. I did this option with my laptop after doing my W10 upgrade and it is a full fresh install as far as I can tell.
